car wont start PLEASE READ!!!
Old Jan 28, 2011 | 05:50 PM
BLK91z-28's Avatar
car: 91 camaro z-28 5.7 350 TPI
engine is only firing on the left bank of the engine, so only 4 cylinders, and I have absolutly no idea why. help would be apreciated, ask questions, cause I really didnt know what info to put down, the car is getting spark all the way around, and 40 psi of fuel pressure to the fuel rail, and all of the cylinders have been compression checked.
thanks
Old Jan 28, 2011 | 06:39 PM
jak's Avatar
jak
Re: car wont start PLEASE READ!!!
By firing do you mean running on 4 cylinders? If it is sounds like your fuel injectors on the r/s are not getting signal...Not sure if there is a seperate fuse for each bank or not..Hopefully someone with a little more knowledge will jump in here..
Good luck
Old Jan 28, 2011 | 07:59 PM
BLK91z-28's Avatar
thanks for the help, I was thinking that maybe the intake ports could be block on the left side, anyone else?
Old Jan 29, 2011 | 10:10 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
there are two fuses for the injectors under the dash, inj1, inj2. one of them is probably blown
Old Jan 31, 2011 | 02:22 PM
BLK91z-28's Avatar
thanks good idea^^^ ill tyry that
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
