Ideal Timing Stock 305 TPI
Old Feb 7, 2011 | 09:01 PM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
I know I have seen it in here, but can't find it...
I have a stock 305 TPI. What would be the ideal timing for performance?? This is a "drive for fun" car not a daily driver, so I'm not woried about gas milage. Just looking for the best overall performance off the line and cruising.
Any help and suggestions??
Old Feb 8, 2011 | 10:59 PM
darrlee's Avatar
Car: 85 IROC
Re: Ideal Timing Stock 305 TPI
Old Feb 9, 2011 | 10:11 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
6 degrees is stock you can advance til it ping and just back it down some
Old Feb 20, 2011 | 03:39 AM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
got a newb question here, wut do you mean by ping? like the engine pings? im young and dumb and plan on doing this same mod here soon
Old Jun 29, 2011 | 05:41 PM
kfairshon's Avatar
From: Maple Falls, WA (5 miles south of Canadian border)
Car: Yellow 85 IROC [Rare 1 of 205 GU6]
Engine: 5.0 TPI(30-over w/forged internals)
Transmission: 700R4 (NASCAR built)
Axle/Gears: GU6 3.42
Starting from the stock 6-degree BTDC spec, advance the timing in two-degree intervals.
With each increase, place the engine "under load." Assuming it's an automatic trans, put it in low, or 1st gear. Then firmly hold the brake down to keep the car from moving. Gradually press the accelerator to increase RPMs to somewhere between 1500 & 2000. When you get to the point where you hear a "rattling" sound (valve ping) under load, retard the timing by two-degrees & re-tighten the distributor hold-down bolt.
A couple of tips:
Before starting, mark your distributor's position. If anything goes wrong and you have trouble, you can always return your distributor to that starting point.
Loosen the distributor hold down bolt just enough so you feel a bit of resistance when you turn the distributor. It doesn't take much turning to change the timing so you don't want the distributor so loose that it turns "freely."
IMPORTANT: Remember to re-tighten the distributor EVERY time you adjust the timing, BEFORE you hit the accelerator to put the engine under load. If you don't, the distributor will turn by itself from the camshaft inertia.
Another caution: DON'T increase acceleration over 2000 RPM or so. Doing so can damage a motor mount. WATCH your engine as you increase the RPM. If it lifts more than slightly on one side, STOP! You probably already have a broken motor mount! In that case, you'll need to replace the mount before you have additional damage.
Hope this helps. Take it slow and a step-at-a-time. Good luck.
Old Jun 29, 2011 | 06:48 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Also does anybody knows around how much should it be at WOT?
thanks,
jaridjohn
Jul 8, 2024 03:49 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
st.evel07
Aug 13, 2015 06:15 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
