WHERE IS MY OIL PRESSURE SENSOR 1989 tpi
Car: 1989 iroc
Engine: tpi
Transmission: auto
Axle/Gears: stock
wHERE IS MY OIL PRESSURE SENSOR on my 1989 iroc with the tpi motor ?
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Re: WHERE IS MY OIL PRESSURE SENSOR 1989 tpi
either just above the oil filter or behind the distributor
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
behind the distributor, 90-92 its above the oil filter. It's a pain to get to behind the distributor
Car: 1989 iroc
Engine: tpi
Transmission: auto
Axle/Gears: stock
can you give me a step by step run down how to change it ? any special tips or hints ?
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
It's above the oil filter, sticking out of the side of the block
Car: 1989 iroc
Engine: tpi
Transmission: auto
Axle/Gears: stock
i think you are right john. its def not near the distributor.
Car: 1989 iroc
Engine: tpi
Transmission: auto
Axle/Gears: stock
john im right next door to you in revere. wanna chill ?
Car: 1990 Firebird Formula 350
I think the oil pressure sender in near the distributor, but the oil temperature sensor is near the oil filter. Two different senders.
Yeah, the last year the OP sensor was up near the distributor was either '87 or '88. My '89 has is right above the oil filter. BTW, go to your local parts store and buy the special "GM Oil Pressure Sensor" socket. Makes it wayyyy easier to replace it. Normal deep sockets aren't quite deep enough to remove the sensor, and it's a royal PITA to do it with a wrench.
Car: 1988 GTA Trans Am
Engine: 5.7
9192camaro
16
02-03-2019 12:21 AM
