idle air control valve delete?
Old Feb 19, 2011 | 07:44 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
so i was wondering if theres away to do this or a by-pass, i have changed this thing more than once and i cant get the idle nailed down, my friend told me he built a block off plate for his on a 5.0 mustang and said it worked fine any thoughts?
Old Feb 19, 2011 | 09:24 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: idle air control valve delete?
the idle air control valve is the ECM's way of controlling the idle speed. The ecm changes the idle speed based on coolant temp, AC on or off, park or neutral, etc. If you unplug it I think you'll get a check engine light. I'd recommend fixing the problem correctly and leaving the IAC in place.
Old Feb 20, 2011 | 01:45 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Have you messed with the minimum air adjustment at all? If you have, it probably needs to be re-adjusted correctly.
https://www.thirdgen.org/tpimod2
Old Feb 20, 2011 | 09:10 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
These types of valves/sensors are on the car for a reason. Get them working right and your car will become more reliable than ever. Throwing parts out because they may need to be simply cleaned or reset makes no sense
Old Feb 21, 2011 | 06:50 PM
tmoble's Avatar
>>>>> ---> cuisinartvette
imagine running into you over here!
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 22, 2015 08:17 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
