LT1 cam in 88 350 TPI
Old Feb 22, 2011 | 12:36 AM
Renoman's Avatar
Car: 98 C5 6sp, 80 El Camino w/TPI, TR6
Engine: LS1, L98, Straight 6
Transmission: 6 spd, 700-R4, 4 spd manual
Axle/Gears: 3.43, 3.27, ?
I posted in an earlier thread that my engine had the peanut cam in it and I was looking for a stock or LT1 cam to replace it. Well I'm receiving an LT1 cam to install in my car and after further research found the "LT1 cam digest (the ultimate one)" on this forum. Although this thread addresses the LT1 swap in the 305 I was curious if the timing gear recommendation of part number 12371043 for the set or 14088783 for just the timing chain and the Comp cam valve springs 981-16 would also apply to my 350. The engine is completely stock at this point. I'm also interested in doing nothing with the timing set and springs and just install the cam with all my old parts. Seems like the engine is already set up for this cam anyway since it's not much different than the stock cam profile. Any feedback is appreciated.
Art
Old Feb 22, 2011 | 12:49 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: LT1 cam in 88 350 TPI
Art
You are good to go. I would put a new timing chain on it though depending on how many miles are on the present. If its the original chain definately replace it.... you may notice a mild gain in performance 1.6 sa roller rockers will get more valve lift which helps performance....These cams make more difference in the TBI engines.
Old Feb 22, 2011 | 02:53 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Art
The stock 350 TPI cam and LT1 cam are almost identical. Only the 305 auto cars had the peanut cam.
Old Feb 22, 2011 | 09:32 AM
Renoman's Avatar
This engine was a dealer warranty replacement take out that a mechanic I bought the engine from had put another cam into. I bought this engine as a short block advertised as a 88 350 Camaro TPI block. I've run it for the last ten years. The mechanic told me he replaced the cam since that was what the warranty replacement was all about. I didn't realize he installed the peanut cam (verified by the part number when I removed it) until I was replacing the intake gaskets and decided to check the cam lobe lift. That is when I discovered the wrong cam was in it. So now I'm just trying to get it back to stock and the LT1 cam seems to be a more abundant cam. I'm just trying to figure out if I need to replace anything. Seems like the minimum will be the timing chain and possibly the gears too.
Art
midge54
Dec 27, 2019 04:14 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
