A pile of TPI's. Whats what?
Old Feb 25, 2011 | 01:24 AM
complete loser's Avatar
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
So glad ive found you all.
Well, ive finally decided to build a TPI motor.
Pretty much the ONLY thing I have that I know what it is, is the engine.
Its an 89' 305tpi engine from a Firebird (suffix code ATA).
Now the confusing part. I need help identifying all my parts so I can put something together and get the proper computer and harness ordered.
I have this distributor Number 1103679
And I have these TPI's. (there is a good chance one of these setups go with the 89' 305 I just mentioned, but the way I used to buy and sell parts... theres no guarantees. )
The left Plenum: 10077151
Left throttle body: 17090154
Left intake: 140069, 10066015
Left fuel rail: 17089024
Right intake: 141310, 10066015
Right fuel rail: 17090101
Right plenum: 10108468
Right throttle body: 17089023
One difference ive noticed is the tb on the left has some kind of airfoil added.
Also, on the left intake the EGR has a terminal and one wire coming from its 7oclock position, where as the EGR? on the right intake has no terminal for a wire, and is infact open underneath.
I am just building a stock 305. So I dont care if I go MAF or MAP. I just need to figure out where to start with this mess.
Old Feb 25, 2011 | 02:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: A pile of TPI's. Whats what?
Makes little difference, same intake used for 305 and 350
Dist will work with all years ; either MAF or MAP setups
Plenum on left appears to be 90 - 92 MAP unit
If rest of intake matches the plenum ( were complete units / not bitsas ) then both appear to be late model setups to suit the later style CB heads
Either will work for MAF also but you will require the MAF sensor itself which you don't appear to have
Old Feb 25, 2011 | 05:34 AM
Twin_Turbo's Avatar
that dizzy is a large cap one for a corvette. uses an in cap coil, the wiring is different from the small cap w/ external coil like on f bodies.
the lower manifolds are both d body manifolds, no rear external fed EGR passage and they have f body fuel rails, if one or both don't have a 9th injector you have the right manifold.
Old Feb 25, 2011 | 07:38 AM
91RS_Charlotte's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.42 Std
Originally Posted by Twin_Turbo
that dizzy is a large cap one for a corvette. uses an in cap coil, the wiring is different from the small cap w/ external coil like on f bodies..
I think it may depend on the year. My F-Body TPI is stock with cap coil.
Old Feb 25, 2011 | 08:34 AM
dans89's Avatar
Car: 85 z28
Mines an 85 and has coil-in-cap.
Old Feb 25, 2011 | 08:36 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
my 91 has the coil off the cap....to be honest ive never seen a TPI car with the coil on the cap
Old Feb 25, 2011 | 09:00 AM
Twin_Turbo's Avatar
Could be then that 85 and maybe 86 used the large cao dizzy, vettes kept them till 91
A 91 F body LB9 or L98 should have a small cap hei.
Old Feb 25, 2011 | 11:39 AM
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
Thanks so much for all the replys. The big issue I was concerned about was using this dist with other setups.
I googled the numbers on the dist, and the info I found says its an 86' 305.
So I would need to get the bronze gear, and would be set I guess.
I do have a brand new MAF. Sorry I didnt include it in the pic.
Some clever people here.
Yes, the intakes are drilled for 87' and later heads.
There is no cold start injector from what I can tell (dont know exactly how to tell). Nothing is coming from the rear of the fuel rails.
I have heard one can confirm a MAP plenum by some tapped holes. Where exactly are the tapped holes?
Ive got so many questions. But I will search out the answer, or start separate threads.
This link may help with the dist/cap discussion.
http://chevythunder.com/fuel%20injec....%20pg%20A.htm
Old Feb 25, 2011 | 11:53 AM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
88 is when they started switching to the small cap ext.mount coil.
Old Feb 25, 2011 | 11:55 AM
Engine: 383 hsr
you can wire your harness for either set up. its just 4 wires. and the wire colors are the same. pretty much snip connectors and splice another one in its place. its easier than switching out a radio
Old Feb 25, 2011 | 07:26 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As I stated above ; dist will work with MAP or MAF
Also as I stated .
The plenum on left is a MAP one because you can see the MAP sensor ( black box with vac line to plenum ) hanging off the rear corner.The plenum has the threaded holes there to mount MAP sensor
Would be on Pass side rear in actual location
Old Feb 25, 2011 | 07:43 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
http://www.hotrodlane.cc/Streetstories/choosingtpi2.htm
Old Feb 25, 2011 | 07:54 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
87s have the small cap(external coil) HEI.
Old Feb 25, 2011 | 07:59 PM
Twin_Turbo's Avatar
can't be, my 87 has it all factory L98
Old Feb 25, 2011 | 08:19 PM
Engine: 383 hsr
my bad, i was a year off. i was thinkin of somethin else lol.
Old Feb 26, 2011 | 12:15 AM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
86 is the last year for the coil in cap,perimiter heads,flat tappet cam, ect.
Old Feb 26, 2011 | 12:18 AM
Car: 1986 iroc Z-28
look at a 85-86 the only 2 yrs that f bodys with TPI have coil in cap
Old Feb 26, 2011 | 12:41 AM
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
Awesome link. Thanks!
Now that I know what the MAP looks like and where its located, I can see that the left intake is a 90'+ and the right is an 89'.
Old Feb 26, 2011 | 01:16 AM
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
Question,
Right now im in the process of deciding MAF or MAP.
This TPI is going in a jeep. And between winter and summer, I sometimes change tire size. Would this be a problem with either setup?
The reason I ask is I was told to specify the tire size when having a MAP computer set up.
Old Feb 26, 2011 | 02:02 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Can't see why
Both setups have a speed (VSS ) input that is used for things like idle control when slowing down and TCC lockup.
The MAF 165ECM has a VSS input from the speed buffer and the MAP 730 has the VSS signal direct to ECM with a output to the speedo.
VSS unit used must match the ECM being used; different output signals
Engine will run fine without the VSS but it is a preferred input
stalkier
Dec 6, 2015 11:25 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
theurge
Aug 21, 2015 12:46 PM
Street Lethal
Aug 14, 2015 08:25 PM
Sanjay
Aug 12, 2015 03:41 PM
