first l98 build
Old Feb 28, 2011 | 09:20 AM
RussC's Avatar
first l98 build
i'm mainly woundering if the cam i'm looking at would be too big for my set up
cam: http://www.summitracing.com/parts/CCA-CL08-466-8/
heads: http://www.summitracing.com/parts/DRT-10511123P/
ported base and runners
also should i get the cam kit with lifters or just get the cam and reuse the lifters i already have?
Old Feb 28, 2011 | 10:13 AM
ray jr's Avatar
Re: first l98 build
alot of people use that cam .. it seems like a good one .. i would do more research on the heads though ..
Old Feb 28, 2011 | 10:20 AM
nomad350Z's Avatar
Car: 1988 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: WC-T5
Axle/Gears: 2.73:1 Open
Re: first l98 build
Depends on what kind of intake setup you plan on running.....
If you're thinking of reusing the stock TPI, I would reconsider both choices. If you're going with a Superram, HSR or other alternative port injection setup, that cam could be a little bigger to get the most out of the engine. The 215cc intake ports would like a Comp XFI-280 instead of the 268, but you may lose low-end driveability unless you tune it right.
As far as the lifters go, it also depends on how used they are. I reused mine, but that was because I had a fresh L98 long block with less than 10K miles on it. I was also told by a local engine builder (his word, not mine) that the factory lifters work just fine since they're designed to last 150K+ miles, but they are heavier and net more inertial losses in the engine.
Old Feb 28, 2011 | 10:38 AM
RussC's Avatar
Re: first l98 build
i'm planing on keeping the tpi for at least a few more years. what would be a better combo? i know afr are considered one of the best but thats way out of my budget. i'm looking at spending around 1000 to 1500 at most.
in regards to the lifters, one of the guys at one of the local shops here told me pretty much the same thing i was just checking what some others thought about it.
Old Feb 28, 2011 | 09:46 PM
ray jr's Avatar
Re: first l98 build
you do realize those dart heads are 1240.00 for the pair .. there are plenty of aluminum heads out there for around that price .. id stick with the 268 xfi cam if your just porting the base and runners ..
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
Tarizza
Sep 24, 2015 12:57 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Winchester1094
Sep 15, 2015 09:48 AM
