7 MPG in City ???
Old Mar 1, 2011 | 05:11 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Transmission: 700R4 Auto
Axle/Gears: G92
7 MPG in City ???
I have a 1992 with a 5.7 350. I am getting terrible fuel economy. Just did a complete tune up with E3 plugs, adjusted timing to factory setting and still I get 7 MPG in the city. I know these cars are not great on gas but 7 MPG ??? The car idles rough when it heats up, and from I read it probably needs new injectors. But would that cause such fuel consumption?
Old Mar 1, 2011 | 08:34 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Re: 7 MPG in City ???
Yes, but even so im not running any emissions and i get an average of 17 mpg IF babied. No check engine light? Map sensor could cause it but not that bad i dont think. The rough idle could be used by injector not pulsating or being bad so its using up more gas.
Old Mar 1, 2011 | 08:42 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
There are a lot of reasons you might get bad mileage. Injectors are a good start. Clean your maf, new air filters, bad oxygen sensor. Scan your computer and see if you have set any codes. How hard are you driving it?
Old Mar 2, 2011 | 10:19 AM
JustCruzin's Avatar
I agree, Question, are you towing a boat lol
Old Mar 2, 2011 | 11:26 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Clean your maf, ?
its a 92 he doesnt have a MAF.
Top 3 things that come to my mind are injectors, O2, sensor, Coolant Temp sensor. I just put injectors in my 91 TA because the stock Multecs crapped out. go to www.fuelinjectorconnection.com and get a set of rebuilt injectors from Jon Banner. Tell him thirdgen.org sent you and you'll get a discount. Do the injectors and go from there. if it still acts up then put it on a scanner and watch the O2 outputs and see if the coolant temp sensor jives with reality.
Old Mar 2, 2011 | 03:15 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
If nothing else, replace the o2 sensor.
Old Mar 2, 2011 | 03:21 PM
Blue1990camaro's Avatar
DING DING DING!
might as well spend the $8 and replace teh water temp sensor for ur ecm while ur at it
Old Mar 2, 2011 | 03:47 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Right on the money!
Old Mar 4, 2011 | 09:50 AM
JustCruzin's Avatar
Old Mar 4, 2011 | 04:44 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
THANK YOU everyone for your advice. First , I am not driving it hard or flooring it. Second the image above is right on the money , I live in brooklyn, today regular was $3.79 a gallon... so yeah I have to cry everytime I fuel up... I'll start with injectors, O2 sensor, fuel filter. I thought if temp sensor is bad it would not show temp on the cluster? Am I wrong?
Old Mar 4, 2011 | 05:19 PM
the coolant temp sensor has nothing to do with the gauge in the dash, that is controlled by a different sender that is in the drivers side head.
Old Mar 4, 2011 | 05:45 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
then I'll definitelly replace it as well. thanks!!
Old Mar 4, 2011 | 06:04 PM
yea, i did new injectors, o2 sensor, fuel filter, K&N air filter, high flow cat, flowmaster exhaust, and it def made a difference, in my 3.1 haha, i miss my 85 iroc sumdays, dont miss the gass milage tho!
Old Mar 4, 2011 | 08:39 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Before you do or buy anything, I have one question for you? Did you unplug the one Tan wire plug on the passenger side of the engine near the blower motor to set the timing? If not, then thats the problem. Set the timing to 6*-8* degrees. No one never ask you this question.
Old Mar 4, 2011 | 09:07 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
I did do the timing after unpluging the wire. I think factory setting was 6*, and thats what I set it as.
Old Mar 21, 2011 | 02:45 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
we're chasing the same problem. So far i've replaced injectors, fixed my rough idle when hot. Replaced O2 because the old one cracked and just did the MAP. After I throw on a new CTS i'll let you know how much my mileage has gone up.
Old Mar 21, 2011 | 03:03 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
If you replace everything and you're still getting terrible mileage when the car is at temp get an ALDL adapter and download tuner pro to see what your computer sees... a past owner could have really messed up the tuning
Old Mar 22, 2011 | 08:22 AM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
At this point I replaced O2 sensor, coolant temp sensor and fuel filter. Didn't do injectors yet. I think I went up to 8MPG now LOL Still have the rough idle though. So will do injectors next. Another issue that I noticed, that at low RPMs, my votage is going up and down. I think this is probably the alternator?
Old Mar 22, 2011 | 08:35 AM
JustCruzin's Avatar
Maybe the injectors just need a good cleaning.
Old Mar 22, 2011 | 12:45 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
if all that doesn't help maybe your cats
Old Mar 22, 2011 | 04:44 PM
you should also check for proper operation of the egr valve
Old Mar 23, 2011 | 02:03 AM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
How do I check EGR valve?
Old Mar 24, 2011 | 11:25 AM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
once you have everything apart for the injectors... there are two nuts holding the egr, (round thing under the intake phlenum)
take it off and look to see if the passages under it are full of carbon.
And make sure the egr can open and close, hold it with both hands and press on the back of the phlenum with your thumbs and watch the valve at the bottom you should be able to see if its hanging open or you'll notice if you cant open it at all.
If you can't open it at all replace it, if its hanging open you can try and clean around the valve with carb cleaner, and clean out the passages with carb cleaner but if there is too much you'll probobly need to take the intake off to get at all of it
Old Mar 24, 2011 | 02:44 PM
theNMBR27's Avatar
Changing injectors made the biggest difference by far. I was using a quarter tank every 20-25 miles of normal driving and 3 inked out bad. So you might check yours just to be safe.
Old Mar 24, 2011 | 07:48 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
Thanks ! As soon as weather gets a little more decent here on the east coast, I'll go for the injectors. I read a few posts, seems that everyone is happy with Bosch 3s from FIC.
Bubbajones_ya
Jul 6, 2024 08:32 PM
bjpotter
Oct 4, 2015 07:48 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
James Sutton
Sep 23, 2015 02:18 PM
ronchic
Mid-Atlantic Region
Sep 15, 2015 08:04 PM
