9th injector
Old Mar 4, 2011 | 08:38 PM
3504ever's Avatar
9th injector
can you still buy a new 9th injector because ive been told they have been discontinued.
Old Mar 5, 2011 | 10:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 9th injector
Rubber expander block plug.
Since it would see engine vacuum instead of pressure, it will hold better then designed.
not sure if its gonna look better.
Old Mar 5, 2011 | 11:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 9th injector
What if he actually want to replace the Cold Start Injector?
Old Mar 6, 2011 | 12:16 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 9th injector
Oops wrong thread, one I was reading said they wanted to plug the hole for good, they unhooked the 9th, thought I found it again to post.
find that post, I know he has a spare 9th
Old Mar 6, 2011 | 06:26 AM
3504ever's Avatar
Re: 9th injector
yes,the actual cold start injector
Old Mar 6, 2011 | 06:53 AM
3504ever's Avatar
Re: 9th injector
yes, the actual injector
Old Mar 16, 2011 | 01:28 PM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Re: 9th injector
Can someone tell me where it's located..? I've never heard of a "9TH" plug. What years did it come on.? Stone
Old Mar 16, 2011 | 02:16 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 9th injector
9th or 7th injectors are also called the cold start injector, might as well call it the choke injector too , aids in cold starting like a choke.
You need a map of Mordor to find it.
Old Mar 16, 2011 | 07:19 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 9th injector
Can someone tell me where it's located..? What years did it come on.?
85 -88
Old Apr 1, 2014 | 02:57 AM
zaxanllc's Avatar
Car: 86 Firebird TA
Transmission: Automatic
Axle/Gears: Stock POSI
Re: 9th injector
Where can i buy one with the connection to the manifold being I cannot sepperate the line from the injector???
Old Apr 1, 2014 | 03:01 AM
zaxanllc's Avatar
Car: 86 Firebird TA
Re: 9th injector
Are you familiar with the 9th injector?
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
ronchic
Mid-Atlantic Region
Sep 15, 2015 08:04 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
