car wont start
Old Mar 10, 2011 | 05:20 PM
z28 350's Avatar
car wont start
i just put a new battery in my 1991 z28 350 tpi then check engine light blinks and it just clicks.
Old Mar 10, 2011 | 05:28 PM
maccamenzies's Avatar
Car: 1988 Transam
Engine: 5litre
Re: car wont start
Starter motor solenoid i would say.Try giving the rear starter motor a light tap with a hammer.Then try starting it.Check the connections from the battery to the starter motor and starter motor from solenoid.Check voltage from battery.Hope this helps
Old Mar 10, 2011 | 05:33 PM
z28 350's Avatar
Re: car wont start
thanks thought it was the starter ill have to check it oout afrer i can move it i think it messed up because the passager side wheel got stuck in a whole
Old Mar 10, 2011 | 05:43 PM
Car: 1988 Transam
Engine: 5litre
Re: car wont start
If its doing a clicking sound when trying to start it will be the solenoid tapping it will sometimes release and throw out the gear and crank the engine.quick way to check is run a wire from the battery to the throw out pole and see if it cranks.
Old Mar 11, 2011 | 06:53 PM
combatdoc's Avatar
Car: 91 z28, 92 ZR1
Engine: LS1, LT5
Transmission: T56, ZF
Axle/Gears: 3.73/ 4.10
Re: car wont start
just take a screw driver and cross the pos. stud to the little stud on the solenoid the that will tell you what you need to know about the starter
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
