Wiring harness help
Old Mar 14, 2011 | 05:50 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Wiring harness help
i have a 350 TPI and dont have the harness and the 350 is in a 86'Trans-am that was originaly a TPI car, can u use a iroc-z tpi harness from ECM to bulk head complete harness with all sensors on a trans-am
Old Mar 14, 2011 | 10:18 PM
combatdoc's Avatar
Car: 91 z28, 92 ZR1
Engine: LS1, LT5
Transmission: T56, ZF
Axle/Gears: 3.73/ 4.10
Re: Wiring harness help
ya should work battery and charcoal canister are on opposite sides though so you have to switch them around
Old Mar 15, 2011 | 04:01 AM
DiabloWS6's Avatar
so u would have to splice the battery and charcoal canister sensors and make them the length to fit
Old Mar 15, 2011 | 10:44 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
No, they are not compatable.
Old Mar 15, 2011 | 11:05 AM
DiabloWS6's Avatar
so i would have to get a harness from a trans-am
Old Mar 15, 2011 | 11:31 AM
Dyno Don's Avatar
Yes, and the same year as yours.
Old Mar 15, 2011 | 12:49 PM
DiabloWS6's Avatar
but what if i have a 1989 motor with out the 9th injector and the distributor is also different from the earlier models
Old Mar 15, 2011 | 06:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You use a '89 prom in the computer ( same computer 86 - 89 )
There are wiring adapters available or you can make your own from junkyard parts to fit a remote coil dist into a HEI setup ;
or just get a HEI dist
Old Mar 15, 2011 | 08:52 PM
DiabloWS6's Avatar
can u use the '88 prom on the '89 motor ...i think ill stay with the remote coil ill just buy or get one from the junkyard
Old Mar 15, 2011 | 10:56 PM
DiabloWS6's Avatar
i also went to the jukyard and found a '85 trans-am tpi harness but was cut on the ecm side so i went to a '86 camaro tpi that had the connector for the ecm so i cut it so i can splice it with the '85 trans-am will this harness work with the '89 tpi 350 motor and ecm that i have or did i mess up
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
