lun-60122 cam in 91 camaro needs tune
Old Mar 16, 2011 | 02:59 AM
s.h.t_camaro's Avatar
Car: 91 Chevrolet Camaro Z28
Engine: 5.7 T.P.I
Axle/Gears: 10 bolt 3.42 Limited slip
Hi people I'm new to this hopefully you guys can give me some insight on my lil problem. I installed the lunati cam 60122 in my 91 350 tpi, I also have edelbrock headers and a 160º thermostat, my question is who has used an aftermarket chip? I heard the ones from summit by motorvation are good and I also have heard about the fast chips. Now do they program these chips pretty good for this size cam, so what I really wanna know is someone who had experience with one of these chips on there car with a cam as big.
Old Mar 16, 2011 | 11:33 AM
AmorgetRS's Avatar
Re: lun-60122 cam in 91 camaro needs tune
Hey, welcome to the board.
You posted in a section that is called:
This is not the place for posting technical questions.
I have moved your post to a more appropriate location.
Old Mar 16, 2011 | 03:40 PM
Engine: 5.7 T.P.I
Thanks I didn't know where to post.
Old Mar 17, 2011 | 09:27 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You will want to try either PCMforless or Fast Chip and ask them to burn a custom chip for your modifications. It may not be perfect the first try but may be better than stock.
The chips you buy off the shelf arent really that good. Usually just some minor timing changes, which can help a good bit on a stock car or mild bolt ons but doesnt always correct the fueling.
Old Mar 17, 2011 | 10:41 AM
Engine: 5.7 T.P.I
Thanks ill check them out and which one can give me a better chip, do you know anything about the ones offered at summit the motorvation brand?
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
Thirim
Aug 13, 2015 03:09 PM
355tpipickup
Aug 13, 2015 07:35 AM
Fronzizzle
Aug 9, 2015 01:15 PM
