88 Camaro Cold Start leak 2.8
Old Mar 18, 2011 | 03:00 PM
Stevenoshow's Avatar
Hey guys, this is my first thread and I don't want to do a swap so don't just tell me to chuck my v6.
I have a 1988 Camaro, and I took it out on the highway and got it up to about 100, when I need to slow down quickly, and put it into second to slow it down, shifted back into Drive, and it died. I pulled to the side of the road, and started it back up and got home with no problem. The next day I was on the way to work, when it started knocking. I have checked the lifters and replaced the timing chain, and there were no problems. I know it is not a rod, because if it was a rod, it wouldn't go away. When I rev it up to about 2500, it will go away for about 10 seconds, and then come back, I had it idling at about 700, and it wasn't knocking either. I am thinking that it is piston slap. But when i removed the Cold Start valve, the seal was ripped, and now i have a gas leak. I have tried buying a new one, but GM has discontinued the part, along with the whole colld start assembly. Has anyone tried to fix this? Any ideas? I also have looked into a kit from a third party site, that bought up all the discontinued parts, and they are charging about 200 dollars for it, and that is ridiculous. Thanks in advanced
Old Mar 19, 2011 | 07:22 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Re: 88 Camaro Cold Start leak 2.8
You might wanna ask this in the V6 forum.
Old Mar 19, 2011 | 07:54 PM
RT66DAVE's Avatar
I couldn't imagine down shifting to 2nd from 100mph, and since these ealy computers have no rev limiters, I suspect you over revved it and it may have valve train trouble. the cold start injector tube seal was availible from GM recently, but i found another in a bone yard.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
