Help with TPI Rebuild
Old Mar 20, 2011 | 08:10 PM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
88 GTA TPI 350
Im having a problem removing the clips on the fuel injectors Ive already accidentally snapped 1 side of 2 of the front visible injectors.
Old Mar 22, 2011 | 11:44 AM
JustCruzin's Avatar
Re: Help with TPI Rebuild
Originally Posted by YoungMoneyVII
88 GTA TPI 350
Is the fuel rail still attached? It's easy if it's out. Don't worry if the clips break they can be replaced plus if you plan to upgrade the injectors you most likely won't need them anyway.
fbirdroller
Sep 2, 2015 10:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
