Original throttle body coolant setup.
Old Mar 28, 2011 | 05:50 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Can anyone provide pictures or a diagram of the original setup for the throttle body coolant lines used to prevent freezing of the throttle plates? Based on what I was told the SI at the dealer only dates back to 1996 and I can't seem to find anything in my Chilton. Thanks.
Old Mar 28, 2011 | 06:04 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Original throttle body coolant setup.
The water inlet on the front of the TB needs a little "U" shaped rubber hose that connects to a fitting on the front of the intake manifold.
The water outlet on the TPS side of the TB has a short hose running to the heater bypass valve, located right at the front of the bank #2 valve cover.
I think my description is better than the picture.
File Type: pdf
Old Mar 28, 2011 | 11:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by eseibel67
The water inlet on the front of the TB needs a little "U" shaped rubber hose that connects to a fitting on the front of the intake manifold..
Old Mar 30, 2011 | 06:16 AM
Mr Froman's Avatar
Awesome!
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
