adding second oil psi gauge questions
Old Apr 4, 2011 | 10:14 PM
GTA350VORTEC's Avatar
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
I have an 89 350 Vortec GMPP Crate Motor in my GTA and recently purchased an autometer oil psi gauge to install in my pillar cluster. However I want to keep my dash oil gauge functioning(as in acurate as it is) Where on a GEN 2 block is there an oil port I can use to install a second oil pressure sender. The back of the block under the distributor doesnt have a port. Any help greatly appreciated.
Axle/Gears: 3:73
Re: adding second oil psi gauge questions
PS, not interested in a T fitting because of space issues.
Old Apr 5, 2011 | 09:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The back of the block under the distributor does have a port.
Old Apr 5, 2011 | 09:56 AM
Axle/Gears: 3:73
I looked quickly last night with a flash light, didnt see it, but I could have missed it, Ill check today again, any other ports anywhere else on the block that are useable for this application?
Thanks Again
Old Apr 12, 2011 | 09:25 PM
Axle/Gears: 3:73
I checked again and there is a port under the distributor, however I have vortec heads and a scoggin dickey base plate and the way the intake is set up the intake runner hangs over the port making a direct install impossible. Any Suggestions?
Old Apr 13, 2011 | 10:43 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's either that port, or a tee in the one above the oil filter.
Old Apr 13, 2011 | 08:53 PM
Axle/Gears: 3:73
where can i buy a T fitting, or is there an extension fitting that I can purchase to use on the port at the back of the block?
Old Apr 13, 2011 | 09:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Any decent parts store will have brass pipe fittings, or a hardware store.
Old Oct 24, 2011 | 06:30 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Not sure about your application but on my 305 block there is a port at the front passenger side of the block just above the timing chain cover. It will have a pipe plug in it. The thread size is correct for an oil sending unit and I have read this is the most accurate location to install the sending because it the furthest point away from the pump.
Old Oct 24, 2011 | 10:06 PM
Axle/Gears: 3:73
Ill have to look at my block, I have a GMPP 350 block, it should still be there unless its blocked by the compressor/smog pump bracket. Do you have any pics available of the port?
Thanks.
Old Oct 24, 2011 | 10:32 PM
Car: 1985 Z28
Just ran out and snapped one for you.
Be aware, if you have the TPI cold start system you most likely will not be able to use this location because the big assed thermal time switch that sticks out the front of the manifold keeps the sending unit from getting the correct angle it needs to screw into the port. I discovered this a few days ago when I tried to install mine. In a few weeks when I swap in a ported manifold I'll be deleting the cold start system so no worries here.
Attached Thumbnails adding second oil psi gauge questions-img_20111024_231820.jpg
Old Oct 26, 2011 | 11:30 PM
Axle/Gears: 3:73
Thanks for the pic. I dont have the cold start system thankfully. Cant wait for a few spare moments to go look at my block. Thanks for the info!! Ill post an update as soon as I try to hook it up.
Old Oct 27, 2011 | 12:37 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I have what you are trying to do and I put mine off the port on the back of the block by the distributor. You can get a tall L fitting and run your line from that. When you run your line be sure and get some rubber vacuum line and put over your copper or plastic oil line since it will eventuall rub a hole through it and cause a big mess. Also, be sure to use teflon tape or silicone on the fitting.
Old Dec 13, 2011 | 09:01 PM
Axle/Gears: 3:73
I finally got a chance to go out and look at my block, and it does not have that port in front of the engine, so I will be forced to go with a T fitting where the stock oil press sending unit is; on the drivers side above the oil filter. I cant use the port by the distributor because I have vortec heads and a scoggin dickey baseplate and it over hangs the port to far. Does anyone know the thread size to that port and possibly a good place to buy a decent T fitting?
Thanks!
PS sorry for the delayed response, got a kid on the way and its been distracting me from my first child lol
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
