injector size for 383?
Old Apr 6, 2011 | 03:38 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I've been out of the loop for a while, all the guys with my join date are mods now
I'm putting a 383 TPI into my 84 Chevy 4x4. I bought the engine from a member on here (kevin) along with a tpi set up (speed density) he had laying around.
what I know about the 383:
1. 4 bolt main
2. 305 heads cut out to 2.02s
3. aluminum roller rockers
4. the tpi is running stock 1LE injectors (I'm guessing 19lbs)
5. was dyno'd some where at 425-450 HP with a carb
my truck:
700r4 trans, 208 transfer case, one ton axles front and read welded with 5.38 gears.
the truck is only used for sunday drives and truck pulls, I will more than likely be adding some "hidden n20"
am I going to want to run the 19s,22s,24s, or 30s
and since everyone loves pics:
Old Apr 6, 2011 | 04:35 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
Re: injector size for 383?
also, what computer should I be looking for? I have the prom burning stuff already and I'll be ordering a new TPI harness.
Old Apr 6, 2011 | 10:47 PM
Iroconian's Avatar
Car: 88 iroc, 89 wrangler
Engine: 5.7
Transmission: t56
Axle/Gears: 3.45
https://www.thirdgen.org/forums/tpi/...tor-check.html
on this forum, the link is in the posting. for 400 hp you will need prob 30lb hr. you will be ok with 24lb hr they will be maxed at 5000rpm with that setup, it does not make HP just robs it. impressive making that much hp with 305 heads
is that a murdered out Jeep in the background?
Old Apr 9, 2011 | 11:30 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
thanks, that is a 'work' 67 CJ5, with a buick v6. it's actually my dads, he has fully restored 71 cj5 with a v6 painted the same color as my camaro.
Old Apr 9, 2011 | 12:05 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I would go 30Ibs myself.
Old Apr 9, 2011 | 01:31 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
...or 24# with an adjustable fuel pressure regulator. The smaller the injector size the better the idle can be.
Old Apr 10, 2011 | 07:17 AM
HorsePowerJUNKI's Avatar
Car: 86 trans am gta,and 88 corvette
Engine: TA-355ci tpi,vette 383 tpi
Transmission: 5spd manual,700r4
Axle/Gears: borgwarner 370 posi,vette is stock
i got a set of 30lb/hr bosch 2 i installed in my 355 tpi .i started it 2 times and they were to much.i purchased a set of 24lb/hr and it runs great.let me know if you are interested in taking these 30lb off my hands.ill let them go for $175 that includes shiping.thanx jon metalrock420@yahoo.com
Old Apr 12, 2011 | 01:33 PM
myzblubyu's Avatar
Car: 1990 Iroc, 1984 Buick Regal
Engine: 5.7, ZZ4 crate w/FIRST injection
Transmission: 700r4, 700r4
Axle/Gears: 3.73, 4.11
I would use a set of Bosch SVO 32lb injectors, adjust the fuel pressure and you are set. I used a set on my built LT1 that made 450hp and they were awesome...
Old Apr 18, 2011 | 05:05 AM
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
yeah i agree 30lbs would be ideal for it, i say get the 350 tpi computer, and burn a custom prom for it,
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
gixxer92
Sep 1, 2015 04:32 PM
knight72
Aug 10, 2015 09:32 PM
