Best plug wires for 85 TPI
Old Apr 7, 2011 | 10:58 AM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
I have an 85 IROC 305TPI. As we all know the original location for the sparkplug wires is under the exhaust manifolds. I keep buring wires from the heat and/or making contact with the manifolds. I am going to spend the money on some good wires this time and run them over the valve covers. (will be adding headers later this year too).
I am looking for some input on what wires everyone has good luck with? What Brands, what size (8mm, 8.5mm or larger)??
I am also going to put heat sheild sleeves over the ends of the wires going to the plugs.
Any input to get the best performance and keep from burning my wires would be great!!
Old Apr 10, 2011 | 04:24 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Best plug wires for 85 TPI
I've had very good luck with Borg Warner NASCAR Select 8mm wires from the local auto parts store. They measure the same or lower resistance than the big dollar wires from the name brands, and they cost a lot less. The ones they specify for our cars are 7mm, but if you get the ones for an 87-95 350 TBI truck, they're 8mm.
Old Apr 11, 2011 | 10:33 AM
jsmith929's Avatar
Car: 88 gta
Engine: 5.7
Transmission: 700r4 with 2400 stall
Axle/Gears: 9 bolt 3.23
I like Taylors the ones spec'ed for our cars I think they fit pretty good just buy some decent hold downs for them .Don't buy the accell wires I got them as a gift and they fit like crap.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Derick15
Sep 17, 2016 05:28 PM
