Fuel Rail Leak
Old Apr 11, 2011 | 03:10 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Fuel Rail Leak
so i have a leak on the fuel rail where the regulator goes. i first thought it was the regulator so i replaced that with a new napa part. the only problem is that i still have the leak!
after ruling out the regulator it seems that the leak is coming from the fuel line that enters the regulator from the front.
has this happened to anyone before? and if so what did you do to remedy the situation.
heres a pic of what im talking about: http://image.chevyhiperformance.com/...mage_large.jpg
its the part that goes from the top of the fuel rail and enters the front of the regulator base.
thanks!
Old Apr 12, 2011 | 11:13 AM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Re: Fuel Rail Leak
Standard part # sk24 is a fuel rail o-ring kit. You'll have to take it apart and replace them.
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
wayshegoes
Aug 17, 2015 12:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
