What to adjust first IAC-TPS
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Just looking to confirm the order of adjustment. I'm pretty sure I would adjust the IAC first, then the TPS. If the idle screw has the TB 100% closed, Then I adjust the IAC as per the procedure. Then I move to adjust the TPS to .54. If I did the TPS adjustment first then IAC the idle screw would move the TPS reading and I'd have to correct it?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: What to adjust first IAC-TPS
Adjust TPS first with the engine off, then the IAC with the engine running....
Car: 89 Formula 350
Remember that the fast idle on the throttle body came "capped" from the factory, so there is/was no reason to adjust the IAC first. Adjust the TPS first with the throttle blades closed, and engine off, then open it slowly to wot and check to make sure the reading is linear and not sporadic. If it's okay, then adjust your IAC....
Originally Posted by TPI-Formula350-
I know what your saying about the factory TB adjustment screw being capped( I have an uncapped Holley TB). My point is if I adjust the TPS first to .54v. Then I put a jumper between A+B in the ALDL, wait 30 seconds disconnect the IAC, if I have to turn the TB screw to get to the desired idle RPM before reconnecting the IAC, this will effect the TPS voltage reading....
Car: 89 Formula 350
Thanks Street Leathal, sounds like a plan.
cool, this is my 1000 post... at this rate I'll hit 2000 in 2019..
LT1Formula
Oct 8, 2015 08:34 PM
