Questions about switching to Vortec TPI
Old Apr 13, 2011 | 12:15 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Alright so I'm dead set on moving to a TPI Vortec setup, I have my 906 Vortec heads, I have my Vortec TPI intake ordered, but I still have my old bolts for the intake and the TPI heads, will they work with the new heads and the new intake or do I need to get new bolts?
Old Apr 13, 2011 | 02:46 PM
myzblubyu's Avatar
Car: 1990 Iroc, 1984 Buick Regal
Engine: 5.7, ZZ4 crate w/FIRST injection
Transmission: 700r4, 700r4
Axle/Gears: 3.73, 4.11
Re: Questions about switching to Vortec TPI
Yes and no... I would never use old head bolts, the intake bolts you can re-use.
Old Apr 13, 2011 | 07:14 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Get some nice ARP head bolts for piece of mind. But you can certainly reuse the intake manifold hardware, if you want to. Those inverted torx were notorious for rounding out, I did not reuse mine.
Will
Old Apr 13, 2011 | 11:18 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Alright thanks guys. Appreciate it.
Old Apr 14, 2011 | 03:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Vortec intake bolts are apparently 5/16" ;
not the 3/8" of reg SBC
"Vortec Intake Bolts are 5/16" instead of the standard 3/8" used on most GM Small Block intakes.
1 per pack, With factory thread sealer. (8 required) "
http://www.summitracing.com/parts/NAL-12550027/
http://www.shopfbparts.com/servlet/Detail?no=143
Old Apr 14, 2011 | 01:14 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Thats what I was afraid of, the bolts being different lengths and different thread counts. Also, I got the head bolts for the 906 heads off of the crate engine, and well they were used, but the engine was never fired, so they're good as new, but they are for a 96-02 long block truck replacement engine. Will those head bolts fit in my 87 305 block with no issues?
Old Apr 15, 2011 | 07:48 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Reason some say to use new head bolts is because used bolts have been stressed when tightened up to spec;
not because they are old
Old Apr 15, 2011 | 08:48 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
May not be related directly to the bolt question, but here's a little extra info. I've heard TPI vortec intakes do not flow very well. I'd look at porting it out a bit to take advantage of the Vortec heads. Just my 2 cents
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
