TPI TB Gasket issues
Old Apr 26, 2011 | 03:08 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
Ok. The new motor for my car is on the stand. I'm putting it together a little at a time while my car is out getting the cage installed. I'm getting to the finishing touches which leads me to some issues. Frankly, the more and more I deal with this, the more and more I'm just getting pissed off. I've got a bigger throttle body I'm putting all the sensors and BS on. Took, the IAC/Coolant assembly off and cut off the coolant part of it, blasted it, and painted it. Looks great.
My issue is this:
DOES ANYONE SELL THE DAMNED GASKET TO PUT THIS BACK ONTO THE TB?
I've went to about every single parts store around here trying to find just the one gasket I need. I'm sure a lot of you, like me, have a billion TB, EGR, and Distributor gaskets, and don't really feel the need to had to the giant stack I already have. Which leaves me to the next question?
WHAT THE HELL IS THAT SECOND TB GASKET THAT ALWAYS COMES IN THE KIT FOR? DID THEY MAKE 2 DIFFERENT STYLES OF THROTTLE BODYS OR SOMETHING?
end of rant/questions.
Old May 18, 2011 | 11:21 AM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Re: TPI TB Gasket issues
i had the same questions, i used the non cardboard looking one. lol Maybe its a spacer?
Old May 18, 2011 | 11:48 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
The 85-89 Throttle Bodies have the triangle in it for the IAC where the later 90-92 (speed density) ones don't.
Old Jan 9, 2013 | 09:37 PM
the blur's Avatar
I too am having gasket issues. 1989 TPI. New TB, new IAC, and the car won't idle. and I went through the idle procedure 10 times. I pull it apart, and I see there are 2 different gaskets. We'll call them open and closed.
I see the closed gasket totally blocks the IAC air, where as the open gasket lets the air through the TB into the plenum.
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
