fuel problems. HELP!
Car: 1989 Iroc-z camaro
Engine: 305ci HO
Transmission: manual 5speed
Axle/Gears: Borg Warner w/ 3.08 gears
Im having trouble starting my 89 camaro . It seems that it drops fuel pressure as soon as the car stops running. After it stops if i don't immediately start the car it won't run without starting fluid sprayed in it, and even that doesn't always work the first time. I was thinking it might be the fuel pressure regulator or the fuel pump. Any thoughts?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fuel problems. HELP!
Check the fuel pump relay - if it's bad then the OPSU is running the fuel pump, and it takes the OPSU some time to get an oil pressure signal to turn the pump on.
Engine: 305ci HO
ok i'll chech that today, but exactly how do i go about testing it bucause i don't think i have a tool for it?
Engine: 305ci HO
I also forgot to say that when my car is off and i unplug my mass air flow sensor it starts quicker, and when i plug it back in while the engine is running the car stalls out right away. Does it need a new mass air flow sensor or maybe a relay?
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Sounds like the injectors are leaking fuel down into the cylinders and flooding the motor. Very common problem. If your pressure bleeds down to zero right after you shut the car off then more then likely the injectors nozzles are shot. The starting fluid is just drying off the plugs and letting it start again.
Omega
Oct 1, 2015 02:20 PM
92camaroJoe
Aug 13, 2015 06:07 AM
