Im stumped please help!!
Old Apr 28, 2011 | 10:53 PM
IROC_Z89's Avatar
Car: 89 IROC-Z
Engine: 350 tpi
I have an 89 camaro 350 tpi and im having major problems. I have a bad hesitation while driving, experiencing backfiring and loss of power. If i pump the throttle the rev will jump all of a sudden but still feel a power loss. I have changed the following: MAF, TPS(adjusted to .54), ignition control module, coil, wires, plugs(ac delco), fuel filter, and adjusted the timing. Still having the problem, retarding and advancing the timing changed nothing so i put it back to stock position. Input would be greatly appreciated thanks in advance.
Old Apr 29, 2011 | 02:21 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: Im stumped please help!!
ohm test your fuel injectors, one bad one can mess up the whole works. anything less than 11 ohm has probably seen better days. 16 or 17 is considered good.
Old Apr 29, 2011 | 03:35 PM
bjm1206's Avatar
I had that same problem among the many others i have, fuel pump took care of that particular issue.
Old Apr 29, 2011 | 03:40 PM
UK-1991-Z28's Avatar
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Look at the injectors I had exact same problem.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
