5.0 TPI S. Density IAC CLICKING NOISE when jumped A-B
Old Apr 29, 2011 | 09:53 PM
numerobis1982's Avatar
Car: 91 Sonoma 4wd w/tpi swap
hi everyone,
i have swapped long time ago in my S10 4x4 a 5.0 TPI V8 it was not s-d but i bought a harness with S-D now the iac is clicking when the aldl is jumped
i have problems ajusting my base timing..
the motor sat for a while outside when i restarted it about 4 years...
i changed the pump+ a new fuel filter + a knock sensor for the S-D as it was recommended by the harness manifacturer
with the timing advanced a lot and not jumped the engine was starting nice but when the truck is in drive it had a tendency to stall
tomorow im gonna plug a GM Tech1 onto it just to check the data
if anyone already had this problem
please help me this would be apreciated a lot
Phil
Old Apr 30, 2011 | 08:09 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: 5.0 TPI S. Density IAC CLICKING NOISE when jumped A-B
The clicking iac is what it should do when the aldl is jumped,
the pindel in the aic is bottoming out like it should
Old Apr 30, 2011 | 10:05 PM
the engine isnt changing sound for base timing like a tbi engine? when aldl is jumped ?
and for setting the base timing just jump aldl? a-b ? or disconnect one wire somewhere..
im running a 1227727 ECM
thejimsterz28
Sep 30, 2015 08:52 PM
Lmancha96
Sep 25, 2015 08:11 PM
steimel94
Sep 20, 2015 12:46 PM
pacoelrapido
Sep 11, 2015 02:41 PM
greenyone
Sep 2, 2015 03:39 PM
