What is the 4th outlet on my gas tank for?
Old May 2, 2011 | 04:43 AM
Blazer79's Avatar
Car: 1986 Iroc-Z
Engine: Stock 305 TPI MAF w 148,000 mi.
I have a clogged return line in my 1986 TPI Iroc. I just replaced the fuel pump a couple of weeks ago, so I'm not happy having to remove the tank again.
During the fuel pump replacement I found that my sending unit has 4 outlets, all different diameters. I have in order from thick to thin:
1) Pump output
2) ??? Was disconnected!
3) Fuel return from FPR <-the clogged one.
4) Charcoal canister
What is 2) for ?
I don't think it's supposed to be just open. These cars have a closed evap circuit, hence the charcoal canister, right?
Also, I remember that the fuel return line has like a check right on top of the sending unit. How is this supposed to work?
I was tempted into using the 2) unknown line as a return line, since this one is not clogged. But it would be a loose fit and would probably have a leak there. Also, I'm trying to do things right and leave my Iroc as good as I can.
Old May 2, 2011 | 05:31 AM
Twin_Turbo's Avatar
Re: What is the 4th outlet on my gas tank for?
pressure vent, the white valve on the bracket above the axle, driver side wheel tub/under body
Old May 2, 2011 | 02:14 PM
Blazer79's Avatar
Car: 1986 Iroc-Z
Thanks for the reply.
I have no valve. It's just a loose hose with nothing attached to it. I can see it aligns perfectly with a hole in the same bracket that holds the brake line. I figure that's where the pressure vent would go. Anyone know a part number or where to find one? Tried googling with no luck.
Old May 3, 2011 | 05:40 AM
Twin_Turbo's Avatar
They are no longer available as far as I know. Your best bet is ghitting the local junkyard
here's a pic, it's the white opaque gizmo
Old May 10, 2011 | 11:31 AM
Scootermunch's Avatar
Car: 1989 Trans am GTA
on this gismo... does it connect to anything else? or just the open line...
just came across the exact same problem on mine. no gizmo.
Old May 10, 2011 | 03:44 PM
Twin_Turbo's Avatar
just the line, it vents to the atmosphere, in essence it's just a 1 way valve
Old Nov 8, 2013 | 09:18 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Wanted to ask about this part, mine has recently started to leak gas when attempting to fill gas?
Little confused on why it would and if your part would cure this?
Old Mar 16, 2014 | 06:49 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
for the record, the white "vent" ya'll are referring to is a one way valve to let air INTO the tank, to replace the fuel being used, not a vent for vapors. the vapor vent is the other line going to the charcoal canister
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
