injectors
Old May 8, 2011 | 02:22 PM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
injectors
are the 1988 5.7 injectors the same as 1989 for yhe tpi system and doyou know the part #
Old May 8, 2011 | 08:40 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
Re: injectors
I would not mess with original TPI injectors. Get some from FIC or Southbay. (Bosch Design III)
http://www.southbayfuelinjectors.com...esign_lll.html
CG
Old May 9, 2011 | 01:54 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: injectors
I personally went with the bosch 3 over the originals and bought them from fic , very happy with them!
Old May 9, 2011 | 09:06 AM
88blackgta's Avatar
Car: 88 GTA Notchback
Engine: 355
Re: injectors
The 1988's are different than the 1989. The 1988's are a Bosch 1 design and the part number on them is 5235302. The 1989's are the first year for the Multec design injectors and the part number on them is 17086545.
(Lucas design injectors, part number 10108481, were also installed on some L98's in 1988 due to production and delivery issues at the factory.)
Old May 9, 2011 | 09:10 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Re: injectors
you can also use for blue top injectors, they're 24# instead of the factory 22# and you can get them cheap off of ebay.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
