ac delete
Old May 10, 2011 | 03:04 PM
87camaro iroc-z's Avatar
Car: Camaro z28 Iroc
Transmission: a/t
ac delete
Another question. After removing the smog pump, i now want to remove the AC also.
The smog pump belt is not the same as the ac.
The ac belt is also connected to the power steering and waterpump if i remember correctly.
Do i need another belt or a delete pulley?
Old May 10, 2011 | 04:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: ac delete
Just get a smaller belt.
Old May 11, 2011 | 10:47 AM
Transmission: a/t
Re: ac delete
Ok, any part number that will fit?
Old May 11, 2011 | 11:40 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: ac delete
I took of my ac and smog pump also..
I am only running two belts..
The 1st belt I have the alternator, with the water pump, and crank pulley..
The 2nd belt I have the power steering pump, with the water pump, and crank pulley..
Reason why I did this was because after experiementing with different ways I can run the belts this was the only way I could of run it.. because my alternator belt would come of, not anymore
If you want a pic let me know I can post one
I could also go with a shorter belt
Valentin
Old May 11, 2011 | 01:16 PM
Transmission: a/t
Re: ac delete
That would be very nice!! Here is a pic of my project car 2a3 years ago
Old May 11, 2011 | 03:24 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: ac delete
Nice pix I wish I had all that space to work on my car here where I live my little garage is like 30feet by 12feet small my car just fits without a problem
Also here is a pix of my belt set up
Old May 15, 2011 | 12:40 PM
Transmission: a/t
Re: ac delete
Thanks. I have a 3 belt setup on this moment.
What did you do with the connection bar between power steering pump and the ac compressor?
Old May 16, 2011 | 02:48 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: ac delete
My car didn't came with them the way you see it is the way I got it expect for the belt format I put it in
Old May 18, 2011 | 07:07 PM
camarotime's Avatar
Car: 1986 Irocz
Engine: Modified TPI
Re: ac delete
By removing your smog pump did it throw off your computer at all?
Old May 20, 2011 | 10:25 AM
Transmission: a/t
Re: ac delete
I haven't started the engine yet. I am waiting for a pair of Hooker 2460 headers and then i am going to build a stainless dual exhaust system.
If i read the topic of the pump it should't give a code but you never know.
Old May 20, 2011 | 11:44 AM
camarotime's Avatar
Car: 1986 Irocz
Re: ac delete
You'll have to share if it effects the computer or not. The only reason I asked was because I know with some of the tpi engines it causes misreadings and does more harm than good to remove it. I'm trying to figure out a way to modify the computer or to make it run normal without the smog pump.
Old May 21, 2011 | 12:44 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: ac delete
On a 89 irocz I am working on we removed the smog pump ad hasn't gave us any problem at all also not even the check engine light has not come on at all
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
