My 86 Z28 wont start.. any ideas?
Old May 22, 2011 | 01:48 PM
Odydog6's Avatar
Transmission: 700R4 (Rebuilt)
86 Camaro Z28 305 TPI..... messin around with the mass air flow sensor... now my car wont start.. check engine light is out, no spark, tested fuel pump(works) but doesnt kick on when i turn the car on.. fuel injectors get power but dont flash at all.. car cranks but wont kick over.. everything was workin fine last night. all these things happened at once.. possible that we jumped the wrong wires on the connector, not sure what happened exactly. any ideas?
Old May 22, 2011 | 02:54 PM
oramac91's Avatar
Re: My 86 Z28 wont start.. any ideas?
Did you reset the computer?
Old May 23, 2011 | 01:15 PM
Odydog6's Avatar
i bought a new one.. still doesnt work.. next step is a wiring harness
Old May 24, 2011 | 05:11 AM
oramac91's Avatar
You try to put a code reader on it?
Old May 24, 2011 | 06:51 AM
luvmy64's Avatar
Sounds to me like the fuel pump relay, if it wont kick on when you turn the key, but it does run if you straight-wire it....right?
Old May 25, 2011 | 02:23 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
check the fuse by the battery, sounds like it blew
Old May 25, 2011 | 04:42 PM
flu_by_u's Avatar
Car: 1989 Firebird Formula
Engine: 350 5.7L TPI
Does it turn over if you spray starter fluid in thru the throttle body?
jaridjohn
Jul 8, 2024 03:49 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
19irocz85
Aug 26, 2015 07:54 PM
