Not satisfied with idle.
Car: 1987 Chevrolet Camaro SC
Hi there..
Short story. The engine is a 87 Lg4 engine that I converted to TPI 2 years ago. I used a TPI set from a 89 camaro so I have deleted the cold start injector and the EGR. I am also familiar with chip burning so I have burned my own chip.
The car is acting okay when driving but I am not satisfied with the idle and the unstable idle after driving for a while.
I have set the idle at 700RPM in drive, cause I have a cam with some higher lift so the engine stalls at 4-500rpm. After I drive for a while and stop the car and put the transmission in park or neutral the RPM jumps to 1300-1500RPM. It feels like the car is being "choked" somehow.
Anyway. When I am adjusting the idle RPM with the IAC plunger fully extended it sounds like the engine operates nicer.
Have anyone of you had some troubles with the IAC valve??
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Not satisfied with idle.
Sounds like the IAC or a vac leak to me.
I don't think it's a vacuum leak but I will check with a vacuum gauge today. I am more focused on the IAC because when I do the idle RPM adjustment with the IAC plunger fully extended the engine sounds happier with only the air that goes through the throttle body.
