do these things actually work/ do anything?
Old May 23, 2011 | 08:49 PM
t/aburgler's Avatar
Car: 85 trans am
Engine: 305 tpi
Transmission: 700r4... for now!
Axle/Gears: 9 bolt 3.42
i was thinking about unhooking the cooling line to my throttle body to keep it cooler and i read that it might do something for power... has anyone done this and noticed a difference? or better yet got a dyno number from it? also the air foil for the throttle body. does that thing do anything at all? doesnt it block an air passage? very curious lol
edit: i read a guy in a technical article hooked up a breather under the car to put air through it to cool it.... would it be possible to do the same thing by hooking the spog pump up to it? and you could add in a box to add ice and cool down the smog pump forced air pumped through the throttle body. just an idea after hearing that.
Old May 23, 2011 | 08:55 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: do these things actually work/ do anything?
Originally Posted by t/aburgler
i was thinking about unhooking the cooling line to my throttle body to keep it cooler amd i read that it might do something for power... has anyone done this and noticed a difference? or better yet got a dyno number from it? also the air foil for the throttle body. does that thing do anything at all? doesnt it block an air passage? very curious lol
Both work, will you gain a significant bit of power? Not really.
The TB Coolant bypass mod will lower the intake charge temps slightly. As its still a metal intake eventually it'll heat soak and it won't matter as much. It does help though so if you can get away with it, I'd do it.
The Coolant flow exists to keep the TB blades from icing up at cruise in colder moister weather. I've never experienced an issue with it, even in the winter months here in Chicago IL. But it can happen, it is there for a reason. Its an easy mod to do, so you could do it for summer, and then undo it for winter if you drive it in the cold.
The TB Airfoil smooths intake flow out a bit. but I don't expect to see a big gain. I think its like 5-10hp at the flywheel at most. it doesn't block any important bits in the TB.
Old May 23, 2011 | 09:13 PM
t/aburgler's Avatar
Car: 85 trans am
Engine: 305 tpi
do you know what it does blocks though?
Old May 23, 2011 | 09:35 PM
Nothing. It has a port for the IAC. See the indent at the bottom in this picture? Thats for the IAC. The blade itself doesn't block anything.
I have something similar on my ported Throttle body.
Old May 24, 2011 | 01:37 AM
karl's-92'-z28's Avatar
Car: Too many cars
Looks like some big*** binoculars......what size is that?
Old May 24, 2011 | 07:14 AM
Just a stock tb ported out to 52 mm
Old May 24, 2011 | 07:42 AM
90FirebirdTA's Avatar
Car: '90 Firebird
i would like to do this, can you explain how to exactly..?
Old May 24, 2011 | 07:57 AM
Car: Too many cars
How is working for you?
Old May 24, 2011 | 08:13 AM
I didn't do it. The guy who's porting my LT1 heads offered to bore it out to 52mm (actually its about 51.7mm, but its close enough) as well as port match my intake.
I didn't actually do any work.
Hows it working? I'll never know. The car is getting ported TB/Intake/Heads, and Cammed at the same time. The individual gains from this will never be known.
Here's a pic of the TB in the porting process. Left is unported, right is semi ported.
There are plenty more links in this link.
http://gallery.me.com/thirdgen89gta#...or=black&sel=1
Old May 24, 2011 | 02:45 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
The throttle body is heated to help prevent carbon build up in the TB as well. That's why I've left mine alone.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
