Charcoal Canister Solenoid Help
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
89 Firebird Formula TPI
I have removed my charcoal canister and plugged the vent line from the gas tank. I was using what I thought was a vented gas cap, only to find out that it is mere a pre-vent type cap that lets the woosh out before you remove the cap. Fuel spills down the side of the car, nasty mess.
I will not vent an open tube out around my car. I cannot find a true vented gas cap. I'd love to if anyone knows where to get one.
I think I need to find a way to hook the CC back up. The issue is the stock ECM is gone, hence I need a way to control the purge solenoid. By just looking at it, there is a 2 wire connector (GRN & PNK); my guess is I need to get 12v and a ground to it. Is this the case? Can I use can constant 12v or should it be switched? Perhaps a rocker switch to apply/remove ground to activate it?
Thank you,
Eric
Thank you,
Eric
Engine: 357 SBC TPI
Re: Charcoal Canister Solenoid Help
Yup, 12v switched and green to ground. But who really wants manual control of the charcoal canister? There's gotta be a better way than this.
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
I'm curious about that myself. I was thinking that maybe a non solenoid canister and TVS to control it say from a '77 Vette. Would that work?
I would also like a simpler canister. I like the idea of keeping it on the car. but the lines are so nasty and breaking. my old thunderbird has a two line set up....
Car: 73 Camaro LT/RS
Engine: 327
Transmission: Supert T-10
Older cars had charcoal canisters that didn't require a solenoid. You could go with one of those.
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I think you would want to hook up the Charcoal Canister directly to the TB, not the manifold. Manifold vacuum would be a huge vacuum leak. I ran mine on my L69 carb'd engine this way for years. Look for a canister from a carb'd car, roughly '85. You definitely don't want to run a plugged vent line.
If you keep the check valves that are just short of the canister, you may have to supply vacuum to that valve. It is designed to keep 2 psi pressure in the tank. Over 2 psi, it will allow flow to the canister. I think the vacuum opens that valve, and once the 2psi is exceeded you have flow. No vacuum might restrict flow.
The check valves are the circular devices? I have one. So the line going to the rear of the manifold is the only line that is sucking air. I am really confused. I apologize. What exactly does the line coming from the TB do?
HTH
Ok so I want the manifold line going to the check valve? which is the circular piece. Then I want the lower TB vac line going to the canister? Is this right? If so what hole with the TB line connect too? You rock man I am getting a visual finally. Thanks so much. The smell of gas is kiling me!
Car: 91 firebird
Axle/Gears: stock
i have a 91 bird with a carb. i kept the canister in mine, it was set by my ecm to turn on once i went 5 miles per hour and up. so i just grounded the one wire and ran the 12 v to the ign. so when i start the car , the canister is open and working . i figure whats the difference, the only time im not goin over five miles an hour is at idle so why not just have it active all the time
i wish i still had the wires to do it. my car has been hacked. i just want to run the lines like an old model car. they had 2 lines and it looked like a coffee can.
