Error Codes 36 & 44
Old Jun 15, 2011 | 12:55 PM
MerethriX's Avatar
Car: Pontiac Trans Am GTA
Transmission: th700
Error Codes 36 & 44
Hi everyone! I just purchased this -88 Trans Am GTA from Calirfornia. Actually one week ago. It got almost three months to get in Finland.
It's my first F-body!! And I love it! Black and 350TPi engine.
But yeah here's the question. SES-light is on and I checked error codes and if I got them correctly it was 36 and 44. Both codes comes three times right??
So what I do??
When I put in on "P" the idle running is sometimes almost 2000rpm. Is it something to do with these error codes?
The throttle cable stays little "open" put just a small touch and it goes back and idle running is ok then...
Sorry my english, I'm trying
Old Jun 16, 2011 | 03:14 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Error Codes 36 & 44
Read this to understand problem
http://chevythunder.com/fuel%20injec...0pg%20a.htm#36
At the age of your car, a new O2 sensor and MAF burn off relay are probably long overdue but check for wiring faults 1st
Rockauto ( rockauto.com) are cheapest for service parts and will post overseas cheaply using USPS if you ask
The throttle cable stays little "open" put just a small touch and it goes back and idle running is ok ..
Throttle cable may be sticking (disconnect cable from TB and check for free movement )
but most likely the throttle body is worn and the butterflies are sticking partly open when you let off the pedal which is why when you tap the pedal they close properly and the revs drop.
Only real fix is a rebuilt one
http://cgi.ebay.com/ebaymotors/TPI-5...Q5fAccessories
( is cheaper to pay the extra core cost than have to post old one back to USA )
or a better cond used TB from 3rd Gen for sale dept
https://www.thirdgen.org/forums/engi...pension-parts/
Old Jun 16, 2011 | 03:43 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
'Throttle cable may be sticking (disconnect cable from TB and check for free movement )
but most likely the throttle body is worn and the butterflies are sticking partly open when you let off the pedal which is why when you tap the pedal they close properly and the revs drop.' very true. mine does as well dude to age, i dont really worry about it to much other then wasting gas. tap it a few times, goes back to normal idle.
Old Jun 16, 2011 | 09:30 AM
MerethriX's Avatar
Transmission: th700
Thank you very much guys!!! Great links also!! I'll try to fix that with those advices!!
Yeah, I also though that the main problem is that it takes more gasoline than normal BUT in Finland gasoline costs about $9 per gallon... (1,65€/litre) so..... So when I fill up my tank it costs about $124 or more..
I dont actually know about US but I think it cheaper there
And I meant that it goes back to normal if I touch that butterfly(?)-thing.. That thing that is under-the-hood-end-of-throttle-cable. I dont know all the english words
Old Jun 17, 2011 | 03:13 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The throttle body ;equivalent of a carb on non injection engines
(commonly called just the "TB" on here)
Old Jun 21, 2011 | 08:32 AM
MerethriX's Avatar
Transmission: th700
Okay! Now I know that! Thnx! I have TPI and u said non-injection engines??
Old Feb 6, 2013 | 07:14 PM
Manknight's Avatar
Hi there all, I own an 83 trans am with 350 carburated engine, the check engine is lighted but can´t scan the computer, I tried connecting a jump wire but stil nothing, can any one help me?
Old Feb 6, 2013 | 08:55 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Will get more attention if you start a new thread titled "can't read codes " or similar instead of re-opening an old one
You are jumpering the correct wires?
https://www.thirdgen.org/forums/tech...s-dumbies.html
Old Feb 8, 2013 | 07:13 PM
Manknight's Avatar
Thanks, you´re right, I will open a new one, and yes I´m jumperin them right, don´t know what to do!!!
Old Feb 8, 2013 | 07:35 PM
Manknight's Avatar
Excuse me, I don´t know how to start a new thread, can you please help me?
Old Feb 9, 2013 | 03:47 AM
jeff_blake's Avatar
select the related catagory, and click new thread to post your own. i agree, you'll get more responses that way. as for the issue i have never came across that before.
Old Feb 9, 2013 | 08:36 AM
Manknight's Avatar
OK Thanks
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
