85 TPI Very Rough Idle in Gear
Old Jun 15, 2011 | 10:24 PM
slt2321's Avatar
Just bought an 85 IROC with the 5.0 TPI, 100k miles. The car had been sitting for 6 months, but the guy said he had this problem before he parked it.
Idling in park the idle will be a little bit rough, but not very noticeable. When the car is in reverse or drive, and im on the brake stopped, the idle is really choppy...missing on a lot of cylinders, but never stalls. While on the gas in reverse or drive, the engine is very strong.
Seems to be a rough idle issue and gets worse while stopped with the car in gear. I dont know anything about the TPI system, but should I be able to fix the problem with a TB and IAC clean, and cap/rotor/plugs/wires? Or am I off track?
Thanks for any help.
Old Jun 16, 2011 | 11:59 PM
slt2321's Avatar
Re: 85 TPI Very Rough Idle in Gear
Bump...
Engine is extremely rough sitting with foot on brake in Drive (or reverse). Accelerating is perfect, idle is smooth for the most part. Have to put the car in neutral at red lights to keep the idle smooth.
Please help, I cant find any other posts like mine on this site.
Old Jun 18, 2011 | 02:04 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
i would start with the trottle positioning sensor when i had it go out on my old toyota i could release the brake and it would stop but then id hit the brake agian and it would start up
Old Mar 18, 2012 | 08:24 AM
leo27030's Avatar
Car: 91 Camaro RS
Engine: 3.1 L V6
Transmission: Automatic
Mine idles rough in drive sometimes if I'm in a drivethru or at a stoplight , the RPM will kinda jump up and down like it's missing but only does it sometimes , but runs fine when I push the gas
jklein337
Sep 19, 2018 06:23 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
