Just dyno'ed the Iroc, good results
Old Jun 16, 2011 | 08:04 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
the car only has SLP runners, and a Flowmaster muffler, besides that its stock. Did this on a Mustang Dyno. Going to hopefully be installing my stealth ram this summer after I buy new injectors and an AFPR. For being internally stock I'm very pleased with this my L98 which has 102,000 miles. Dyno numbers are 223 hp and 336 ft lbs
Old Jun 16, 2011 | 08:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Just dyno'ed the Iroc, good results
.....and the results are?
Old Jun 16, 2011 | 08:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Not bad at all...mustangs read lower than dyno jets so thats about high 230's or so on a dynojet, maybe more. Thats pretty good for a L98 with runners and muffler only.
RPM seems way off tho...how did they capture rpm? Did they set it up with a tach pick up on plug wire or did they try to match roller speed to engine speed at 3000 rpm?
Old Jun 16, 2011 | 08:14 PM
tach pick up wire on the plug wire, the rest of the guys had been whining about low numbers, but the camaro seemed to come out pretty good
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
mustangman65_79
Aug 11, 2015 03:17 PM
