305 tpi issues help !!!
Old Jun 22, 2011 | 07:03 AM
bad_to_the_bone's Avatar
Car: 89 iroc-z
Engine: 427 bbc
Transmission: borg warner t-5
Axle/Gears: 3:23 posi
hey guys im having a couple issues with my 86 iroc-z its an automatic and the 305 tpi of course
issue 1 when i got the car last weekend the car was not running that well so i was looking for any isses and came across the ect wires being frayed and the conector being broken so i found a connector and replaced its with solder and shrink tubed it at the same time i replaced the temps sending unit for the guage and the sender for the rad fans... now the car runs awesome and the guage still does not work any ideas??
issue 2 when i slow down with the car in drive i noticed my rpms fluctuating up and down roughtly 500-1500 rpm and never conssistant is this normal or do i have an issue with the idle air control or something else ????????
Old Jun 22, 2011 | 09:03 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
Re: 305 tpi issues help !!!
with your rpms i have the same issue they jump around and some times it stalls on me... it use to stall alot but i noticed that a plug in under the MAF was unplugged and it helped it rpms dont jump as bad but in my MAF sensor the screens are cut out so that could also be a problem if yours are also
Old Jun 23, 2011 | 08:02 AM
Car: 89 iroc-z
Engine: 427 bbc
no tthe plug for the maf is connected and no issues there and the screens are still intact with mine wondering if it could just be dirty
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
