missing wiring connectors
i was hoping i could get a little help i saved this 88 GTA L98 coupe from being crushed. but the harness had the engine management chopped out so i bought another harness but it's missing a few connectors.
1: 3 wires. black with white stripe, black, and brown?? on the drivers side.
2: 1 wire. white goes through the steering column.
3: 2wires. black with white stripe and the other is tan on the passenger side.
any info or pics of these would be great thanks.
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: missing wiring connectors
i am not sure what those wires are for but you might wanna check out hawksthirdgenparts.com
if its not on the site call them....they probobly have whatever you are looking for
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Looks like one and three are grounds to the back of the cylinder heads, and two is probably your tach lead. Kind of confusing where they are laying though.
i think pic 3 was grounded to the firewall with the ground strap on the old harness but they were basic crimp rings and it didn't look right. but pic 2 just comes out of the firewall under the steering colmn by itself.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
wiring diags help?
http://www.austinthirdgen.org/index.php?pid=19
Many connector ends can be ordered from any auto parts store - look them up in this online catalog, then order Dorman part # xxx
http://dormanproducts.com/flipbook/2...log/index.html
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
