How much power?
Old Jun 25, 2011 | 07:21 PM
schmitzdonald68's Avatar
Car: 1991 Z28 Convertible
Engine: 5.7 TPI
Axle/Gears: rear discs from 88 IROC/272 gears
How much power?
OK, so I am finished with my 5.0 to the 5.7 swap with rear axle swap as well. All running pretty smoothly, but I am wondering, how much horse power is capable from this motor leaving it as a TPI set up with out adding Nitrous and staying normally aspirated? Any ideas?
Any recommendations as to what my next modification should be?
Thanks all!!
Old Jun 25, 2011 | 10:07 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: How much power?
There are several here that have dyno sheets for 400 HP w/LTR's at the flywheel but it appears to be a lot of work/money. Headers/exhaust, heads, cam, intake, in that order. And, a razor sharp tune. Unless you're going racing, don't be too concerned with horsepower numbers. Enjoy the torque of a TPI on the street.
Old Jun 25, 2011 | 11:26 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: How much power?
for cheap but a lot of hp go for cold air intake exhaust and afpr
Old Jun 26, 2011 | 06:51 PM
Engine: 5.7 TPI
Re: How much power?
OK, so my blonde is going to show on this one, but what is AFPR? and any recommendations for exhaust/cam/head combo's...there are just so many of them and I am not made out of money to just start trying stuff. which i am sure most of us aren't.
Old Jun 26, 2011 | 10:01 PM
watajob's Avatar
Car: 92 T/A 'vert
Re: How much power?
Adjustable Fuel Pressure Regulator. And, for about eleventy jillion discussions of the pros and cons of different go fast parts.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
