Where does vapor canister line hook up to TPI? Throttle body?
Car: 2000 BMW M5
Hi guys I have a TPI swap that is running great but I think I hooked the vapor canister vacuum source up to the wrong port. I used a full manifold source on the rear passenger's side of the TPI manifold as the vacuum source supplied to a vapor canister that I got from a TPI parts car. Is the vacuum source for evap actually supposed to be the throttle body? If so which port.
Also where is the EGR vacuum source supposed to be? I used the small nipple on the bottom of the throttle body as the EGR vac source.
Steve
Steve
Car: '88 white Iroc-Z
Re: Where does vapor canister line hook up to TPI? Throttle body?
If I remember correctly,both the EGR and EVAP vacuum were hooked together to the vacuum port on the throttle body. That's on a '88 LB9. EGR is long gone but I've hooked the EVAP line back to the TB. Check the underhood vacuum line routing sticker for your specific year as there are not all the same (should be available on this forum somewhere).
Car: 1988 Formula
Transmission: TH-700-R4
Axle/Gears: BW 9 bolt 2.77
The pvc goes on the top vent, it is not a vac line the vac for the PVC system is on drivers side betweene the runners
Then the evap can goes on the bottom full vac line.
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
1992 Trans Am
May 10, 2023 07:19 PM
