305 tpi idles fine then randomly dies ????
Old Jun 28, 2011 | 11:37 AM
bad_to_the_bone's Avatar
Car: 89 iroc-z
Engine: 427 bbc
Transmission: borg warner t-5
Axle/Gears: 3:23 posi
hey guys after changing all the temp sensors and fired up the car sometimes it has a hard time to stay running on its own so you keep it reved up a little it works great then you let it idle for a bit and it will stall while its in park and no one near the car then.... and when slowing down from 40-50 mph the rpm willl fluctuate up and down between 1200 and 2000 rpm??
please help with any thaughts im thinking it could be the tps but not sure
Old Jun 29, 2011 | 10:51 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Re: 305 tpi idles fine then randomly dies ????
IDK exactly but it could be a vacuum issue,check the egr valve first.but mine started surgig like that then finally wouldnt start at all,come to find out one of my injectors is shorted out which is shorting the ground out on the inj circuit.I can unplug the one inj and itll start and run(rough) but it'll go straight dead when I plug that one injector in..maybe this helps maybe not but its my experiences...wish you well man
Old Jun 29, 2011 | 11:10 PM
dbcisco's Avatar
Car: 1992 Z/28
Adjust the idle set screw to keep the plate open after the IAC closes.
Old Jun 30, 2011 | 06:25 AM
Car: 89 iroc-z
Engine: 427 bbc
well when it does not act like it wants to die it idles around 900-1000 in park and in gear like 700rpm so i dont beleave its the idle preset jut randomely acts up does not do it all the time and after it dies i have to keep it reved up a bit untill it stops acting up and then its fine for a little bit its tempermental lol
Old Jun 30, 2011 | 10:42 AM
dbcisco's Avatar
Car: 1992 Z/28
I'm at a loss,sorry. That was what worked on mine.
Old Jul 25, 2011 | 07:53 AM
Car: 89 iroc-z
Engine: 427 bbc
well i found out i have a bad connector on the mass air and im hoping this is my problem !!!
BlueIroc-Z
Jun 9, 2019 03:22 AM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
