looking for a how base
Old Jun 28, 2011 | 06:31 PM
A K racin's Avatar
was wondering if there is a how to remove the lower intake (base) on a l98
Old Jun 28, 2011 | 10:42 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: looking for a how base
It comes off like any other SBC, once you get the plenum and runners off. Just realize the runners have bolts coming from the center of the intake manifold also. You'll see them after you take the plenum off. Just don't hit anything with a metal hammer! The gaskets will hold it together after you remove the bolts. A rubber hammer, used gently will separate the plenum from the runners.
Old Jun 28, 2011 | 11:49 PM
A K racin's Avatar
ok thanks was just wondering have to remove fuel rail
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Sep 28, 2015 08:00 AM
