finishing 355build..need imput.
Old Jul 4, 2011 | 02:22 PM
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
i have freshly redone 355. 10:1, comp cams grind number cs xe268h-10 thats .477intake .480exhaust with a 224intake and 231exhaust duration. 110 lobe separation and 106 centerline. I have a holley stealth ram intake/bbk 52mm throttle body with AFPR. Ran off of a speed density tpi. I have brand new 113 aluminum corvette heads with upgraded springs. My questions is should I opt for the 1.6 rockers over the 1.5's and should I use 30lb injectors over the 26lb. I'll more then likely buy from summit and 28's aren't available in my application.
Old Jul 6, 2011 | 09:37 PM
Abubaca's Avatar
Re: finishing 355build..need imput.
I would think that with the stealth ram, you could certainly take advantage of more lift. Maybe 1.6's? ...bump those lift specs up to around 508/512
...and I doubt you'll need more than 26# injectors. You'd probably be fine with 22# or 24# pounders.
Old Jul 9, 2011 | 05:49 PM
Car: 88 IROC
Engine: 305TPI
yeah with 1.6 rockers it should be close to the LT4 Hotcam...just a hair more durations... I'm told so many different things with the injectors I don't know what to think.
Old Jul 10, 2011 | 12:12 AM
Abubaca's Avatar
Well here are my thoughts on the injectors. Keep in mind I'm not an expert. The 355 for all intents and purposes is a 350. Same as stock. The Vette heads, unported are basically stock. The cam is by no means stock, but it ain't huge either. Just a little more duration than my ZZ4 cam, and assuming 1.6 lifters, just a few more thousanths of lift. Regardless of intake, if naturally aspirated, there's only so much air that engine is going to use, and therefore only so much fuel needed. I ran just fine on 22# with a stock tune, and had to retune for less fuel when I added the 24# SVO injectors (stockers died). Please don't make a final decision on my word, but I can't see needing that much injector.
Old Jul 10, 2011 | 09:05 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I would go 30's myself, either way your going to need to burn a new chip for it and that what really matters.
SRKLEGIN
Oct 29, 2015 06:38 PM
91 SrS
Oct 7, 2015 04:32 PM
loud91rs
Oct 5, 2015 10:05 PM
James Sutton
Sep 23, 2015 01:56 PM
Linson
Sep 21, 2015 01:08 PM
