FPR: Is This Bad?
Old Jul 7, 2011 | 07:47 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
FPR: Is This Bad?
I was just poking around in the engine bay scouting my Plenum disassembly route, and when I removed the vaccum line that goes from the fuel pressure regulator to the back of the Plenum, there was fuel in it. Maybe It's just me being paranoid, but I don't recall this being a good thing in regards to the FPR diaphram. Can someone chime in on this?
Old Jul 7, 2011 | 07:50 PM
Twin_Turbo's Avatar
Re: FPR: Is This Bad?
ruptured diaphragm, should be no fuel in the line
Old Jul 7, 2011 | 08:03 PM
Car: 1985 Z28
That's exactly what I thought. This causes the engine to run rich, correct?
Also, when purchasing an adjustable FPR such as a BBK unit, does it include the a diaphragm and all as a bolt on turn-key mod?
Old Jul 7, 2011 | 08:06 PM
Twin_Turbo's Avatar
yes, the fuel gets sucked into the TB causing a rich condition.
Yes, adjustables are all complete ready to bolt on.
Old Jul 7, 2011 | 08:13 PM
Car: 1985 Z28
I just looked all over the net and couldn't find any mention of whether or not the BBK 1714 kit comes with a diaphragm. However, when I looked the part up on summit it said in the notes, "Must re-use stock diaphragm and spring assembly"
Old Jul 7, 2011 | 08:38 PM
Twin_Turbo's Avatar
Oh those are only hats w/ a screw to adjust it then, figured you meant a complete FPR
Old Jul 8, 2011 | 03:11 AM
Car: 1985 Z28
I was checking and it looks like advance auto sells the diaphragm:
http://shop.advanceautoparts.com/web...674035144____#
But, look at the one comment:
This will not work with the chevy Fuel Pressure Regulators, they are a sealed unit..........you will need to replace the hole unit.
Has this guy lost his mind? I thought one you removed the allen screws the FPR "hat" comes off to expose the diaphragm?
Old Jul 13, 2011 | 02:05 AM
Car: 1985 Z28
When I removed the diaphragm, this is what it looked like. What would cause the rubber to rot out like this?
Attached Thumbnails FPR: Is This Bad?-img_20110713_030133.jpg
Old Jul 13, 2011 | 10:09 AM
GTA90X's Avatar
Car: 1990 GTA
Engine: stock L98(being pulled for rebuild)
Transmission: stock 700R4
Age, heat and constant exposure to gasoline. Nothing lasts forever
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
