91 tpi will not start
Old Jul 12, 2011 | 05:21 PM
05colorado57's Avatar
i just rebuilt m 91 305 tpi it has 40psi fuel, good spark and good timing, now the spark plugs are dry and dont smell like gas, the engine just turnes over anyone know ???
Old Jul 13, 2011 | 11:31 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: 91 tpi will not start
Are you getting injector pulse? If so, are you getting about 20miliseconds while cranking? You'll need a scanner to check injector on time. Look at ECT on data stream to see if it seems right.
Check TPS. If TPS is over about 4 volts, the ECM will go into clear flood and shut down injectors to clear a flooded engine.
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
