Code 42&43
Old Jul 22, 2011 | 08:31 PM
daveb8's Avatar
Code 42&43
Hello all. I am at the end of a tip swap in my 64chevelle ( giving it to my dad) and I am getting a code 42 &43. I have all new sensors including the distributor and injectors. I have the dizzy plugged in in the rear . Timing set at 6 with it unplugged . I also have 5 volts to the knock sensor.
My ohm readings on the knock sensor are around 1. I believe they should be around 3 from everything I read. So I am thinking I have the wrong knock sensor.
I just want to see if that seems like the problem to everyone before I go drop another chunk of money on a new knock sensor.
Also when I start the car and have my scanner on it. If I give a few knocks on the exhaust manifold with a hammer the scanner is saying yes to a knock.
The motor and injector rail is 86 5.0 liter. I switched the wiring and computer to a speed density system.
I have been reading and it seems the code 43 sets a code 42 a lot of times.
So would I be correct to think if I get the right knock sensor everything should be good.
Old Jul 23, 2011 | 08:09 PM
daveb8's Avatar
Re: Code 42&43
new knock sensor solved 43. Still working on 42. Any thoughts. I keep searching ,but most of the code 42 answers I find is not for speed density.
Old Jul 24, 2011 | 01:35 AM
Moe87's Avatar
Re: Code 42&43
from my haynes manual:
code 42 - electronic spark timing - poor electrical connection, open or short in circuit, Defective ignition module.
hope this helps. if you need any more info from my manual or wiring diagrams, pm me
Old Jul 24, 2011 | 10:22 AM
daveb8's Avatar
Re: Code 42&43
thanks. I am trying to find a flowchart or something with some specs. Thanks...
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
