INJECTORS!!!
Old Jul 24, 2011 | 02:20 AM
oramac91's Avatar
INJECTORS!!!
WHAT best brand name name injestors to buy?Should i go 42 or 48.92 z......buildet up a bit.New motor.9.1 pitons ported and polished heads. camed.350 OF COURSE!!!
Old Jul 24, 2011 | 08:51 AM
S10Wildside's Avatar
Re: INJECTORS!!!
An engine runs (well) because it maintains a good air/fuel ratio. During normal operating conditions it maintains a 14.7:1 air/fuel ratio. During wide open throttle it runs a little richer. If you put a set of 42# injectors into a 350 engine (without a SERIOUS power adder like supercharger or turbo), the engine will never be able to suck in enough air to maintain a good air/fuel ratio. Even for a 383ci engine with no supercharger or turbo, a 42# injector is way too much. You'll lose power and blow unburnt fuel out the exhaust as black smoke. Stick with 24# or 30# injectors and then a custom tune.
It's like the fat guy at a buffet. Feed him too much food and he's fat, slow, and will pass unwanted gases.
Old Jul 24, 2011 | 09:29 AM
Johnnygeek's Avatar
Car: 1988 Formula
Transmission: TH-700-R4
Axle/Gears: BW 9 bolt 2.77
Re: INJECTORS!!!
IMO Bosh makes best injectors.
hard to tell how much fuel your monster needs till it fires up...
you will need a Adjustable fuel pressure regulator AFPR
you will need a new chip made.
you might need a heated O2 sensor
headers and a nice exhuast is needed too...
google injector calculator basicly get the injector for the horse power your hiting
or run a holly carb...
Old Jul 24, 2011 | 06:37 PM
southbay08's Avatar
Re: INJECTORS!!!
IMO Bosch makes the best product out there!
Old Jul 25, 2011 | 12:40 AM
oramac91's Avatar
Re: INJECTORS!!!
have headers. 3in exhuast..... no tpi stock.HMMMM guy at speed/ tunning said i could go with 42.48?
so he is wrong?
Old Jul 25, 2011 | 04:25 AM
Re: INJECTORS!!!
so he is wrong?
An injector that big on such a mild 350ci engine (or any 350ci engine without forced induction) will cause issues with idle. The minimum pulse width (on/off) of the injector will cause the ECM to have a difficult time maintaining a decent idle while too much fuel is delivered. There comes a point where you can't "tune it" because the injector flows too much at minumum pulse width.
If you go with such a high flow injector, expect your tuner to raise the minumum idle several hundred RPM because he won't be able to get the engine to idle well.
Your engine cannot flow enough air for 42# injectors.
Old Jul 25, 2011 | 05:54 PM
oramac91's Avatar
Re: INJECTORS!!!
ty
Old Jul 25, 2011 | 06:02 PM
Dirt Monkey's Avatar
Re: INJECTORS!!!
Lol, love the fat guy analogy..Awesome! True too!
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
