89 Iroc Alternator/power steering mount bracket
Old Jul 28, 2011 | 10:04 AM
bluegrass's Avatar
Car: 1989 Camro Iroc
Engine: 5.7 tpi
Axle/Gears: 2.77 BW
Im looking for the bracket the alternator/power steering pump are connected to. The bolt hole the alternator bolts to has broken off. Anybody know where I could find this entire mount bracket?
Old Jul 28, 2011 | 02:20 PM
bluegrass's Avatar
Engine: 5.7 tpi
Axle/Gears: 2.77 BW
Re: 89 Iroc Alternator/power steering mount bracket
when in doubt call Hawks!
Old Jul 28, 2011 | 08:29 PM
dongc1's Avatar
They are on Ebay all the time
Old Jul 28, 2011 | 11:27 PM
bluegrass's Avatar
Engine: 5.7 tpi
Axle/Gears: 2.77 BW
yea i seen that
Old Jan 7, 2013 | 11:47 AM
fastgascar's Avatar
Just in case someone needed this part, here is the part # 10105212
Old Mar 10, 2013 | 10:35 PM
johndinu's Avatar
Car: '89 GTA 350 hardtop
Hi,
I have found mine on rockauto for $60ish.
Just a note that the alternator become a little noise prior to letting go. Did not bothered to check that out:-(
The crack in the bracket looks like typical fatigue. Now I am removing it and noticed the first bolt from the top left-as u look at it from the front of the car- (right under the piece which broke off) a trox head which secures the bracket to the head was completely loose and broken off too (fatigue).
As crazy as it sounds I tend to believe that the bolt broke off first... Will ask a specialist. Now if this is true, check that bolt for tightness. If loose remove (should be about 1" long, mine was broken right in half) and put a new one in place
A chance these parts are still available to buy new...
UPDATE: I have asked a specialist. He said indeed the bolt worked itself loose then broke from fatigue. This in turn put more load on the tab which bolts onto the alternator and caused it to fracture. After the tab let go the whole alternator case split in half (alternator was hanging by the wires).
Don't let this happen to you;-)
Check this trox head bolt for tighteness every season. If found lose replace (even if not broken, chances are it's cracked allready). No need to apply loctite
I just spent $8,60 for a new one @ the stealership. It's aait, they don't see my face often around there;-)
Now to get the broken part of the head... another story:-(
UPDATE2: I found another broken stud (1st stud from the bottom, nxt to flywheel). I will replace all 5 (3 trox headed bolts and 2 studs) with new Gr10 ones.
will check the A/C bracket next and most likely replace everything
Was wondering if this is pertinent to a TPI car? (I do not have the two braces (#5 in the pic)
Attached Thumbnails 89 Iroc Alternator/power steering mount bracket-2013-03-15-12
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Out-Cast
Mar 22, 2019 09:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
