Adjustable Fuel Pressure Regulator (AFPR) needed!
Old Aug 9, 2011 | 10:53 AM
Rezi1987TA's Avatar
Car: 1987 Pontiac Firebird Trans Am
Axle/Gears: 3.45
I ordered a Cam and will be needing an AFPR with not much money left :-S
Which one is the cheapest one worth buying?
The engine is 87 305 TPI.
Old Aug 9, 2011 | 02:25 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: Adjustable Fuel Pressure Regulator (AFPR) needed!
Mallory AFPR for $60
http://www.aztpi.com/product.php?pro...&cat=10&page=1
Holley $95
http://www.summitracing.com/parts/HLY-512-501
The Holley is more money, but I like the way it adjusts better- more of a thumb wheel dial on top. Getting a wrench into the adjusting nut on most APFR's is pretty tough once the Plenum is installed.
You can also modify a stock unit. Do some Google searches for DIY APFR mods. It takes a nut welded to the top of your APPR housing, and a bolt that will move through that nut to adjust the pressure on the spring. Not to difficult, but finding the instructions and pictures will be nice.
Old Aug 9, 2011 | 05:55 PM
Rezi1987TA's Avatar
Axle/Gears: 3.45
Thanks a lot. I was looking at those two. I bought the first one cause I had exactly 70$ left on my account. :-))) Hope it works fine and won't give me a pain in the ............ :-)))
Old Aug 10, 2011 | 12:40 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I like the holley one because of the way it adjusts easily by hand w/o tools. but mallory makes good products so im sure you'll be happy with it.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
