Need Help with click noise after car wouldnt start
Old Aug 9, 2011 | 07:54 PM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
I have a 1987 camaro iroc with a built 350tpi 5speed....the prob its havin is somethign with the ign.it would run great around 2months ago around town then out of no where die like its not getting fuel or battery died...well the last couple of days it would die sooner like a sensor is getting worst..i just replaced the coil on the dizzy.now that it wont start and after i turn the key over not starting it i can hear a click noise coming from the driver side front of the fender from a relay it looks like with 3 wires goin to it...with the key on it will click every 20secs.heres a pic of it....need to know what this does and if it could be why my car doesnt start....thanks
Attached Thumbnails Need Help with click noise after car wouldnt start-sam-pic.jpg
Old Aug 10, 2011 | 09:21 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Re: Need Help with click noise after car wouldnt start
That could be the fuel pump relay. If it is that will definitely cause your starting and running issues. They are fairly cheap like $12-$15.
Old Aug 10, 2011 | 01:46 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
ohm your fuel injectors too.
Wade787b
Sep 29, 2015 01:15 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
86Base
Aug 8, 2015 01:34 PM
