Performance chip ??
Old Aug 9, 2011 | 05:12 PM
tazz3871's Avatar
Performance chip ??
Hey guys gals I just purchased a GTE Stage 1 performance chip for my 87 GTA L98 5.7 the first paragraph states the following "Warning: Please install this module at your own risk. GTE will not be held liable for any damage to your vehicle,yourself or property,and was wondering if any of you have installed a performance chip if you encountered any engine problems once chip was installed.thanks a bunch
Old Aug 9, 2011 | 05:26 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Performance chip ??
Standaed Warning in case you damage the ECM at installation. (Static Electrical charge). Really don't expect this so called perforance chip to be a magic bullet for your car. All it will do depending on the vendor, just change a few parameters over stock
Old Aug 10, 2011 | 02:00 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
That is a device which is basically a resistor. It installs on the IAT sensor . Intake air temp sensor under the tpi plenum. All that does is trick the ecm into thinking the actual air temp is colder/hotter than it actually is thus making it richen up the air/fuel mixture. A 4.7k resistor will do the same thing. Can be purchased at a local Radio Shack for a dollar or less.
Old Aug 10, 2011 | 02:02 PM
ninetyone's Avatar
Axle/Gears: 3:42
A perfomance chip installs in the ecm itself. I would return that thing.
PurelyPMD
May 5, 2016 04:57 PM
85 Jimmy
Sep 30, 2015 07:56 AM
ramicio
Sep 28, 2015 01:18 PM
Deemax
Sep 12, 2015 06:53 PM
